InHand Industrial Switch – First look
***WARNING — I thought there was a problem with this switch — turns out the problems are with my eyes and not seeing the set button in the bottom right hand corner of the screen. I figure this out and correct myself in the video*** The first time you’re seeing this switch, is the first time I’m seeing this switch. Let’s look together!
In our qwest to touch all industrial switches, next is the InHand ISM5012D. With operating temps from -40 – 185F this switch should have more than enough configuration options to keep your industrial network flowing. The switch features 8 Gigabit Ethernet ports and 4 SFP 1Gb ports.
It’s an interesting switch but the firmware is from 2021. I’m hoping there is a new firmware version available.
Curious and want to put this switch through your own tests? You can purchase one here:
Amazon Affilate Link: https://amzn.to/3DBegvS
I’m going to be running this switch and all the others in the lab over the next couple of months to see how they work — and then we’ll move them outside!
