Ubiquiti Networks – Accessories – Ethernet Surge Protector
Sometimes a surge or ESD (electrostatic discharge) can be the enemy of your networking equipment. Ubiquiti Networks has the ETH-SP (Ethernet Surge Protector) to help alleviate surges and ESD from damaging your equipment. This product can be used with ANY manufacturer’s equipment. It supports speeds up to 1Gbps.
From the Ubiquiti site:
https://www.ubnt.com/accessories/ethernet-surge-protector/
Ethernet to Ethernet Grounded ESD Protection
The ETH-SP is engineered to protect any Power‑over‑Ethernet (PoE) or non‑PoE device with connection speeds of up to 1 Gbps.
ESD Protection for Outdoor PoE Devices
Damaging electrostatic discharge attacks and surges are diverted to the ETH-SP and safely discharged into the ground, so network devices are protected.
Additional ESD Protection
All Ubiquiti® airMAX® devices are equipped with built-in ESD protection, so the ETH‑SP adds another layer of protection to your outdoor, high-speed network.
Plug and Play Installation
Connect the ground and Ethernet cables in between your network devices.
Only ~$12 for a little insurance and piece of mind!
Please give a thumbs up, subscribe, share, and comment!
