Ubiquiti UniFi 5.2 Beta Upgrade
Local firewall rules video coming this week!
In this video we upgrade our UniFi 5.1.1 Beta controller to UniFi 5.2 beta.
5.2 Beta Notes:
Notes:
As always, make a backup prior to upgrading.
Windows users must have x64 Java installed as we only support 64 bit webRTC library. Please see HERE and download the missing version (64bit offline Windows install package).
You cannot re-use a VLAN ID for dynamic VLAN if it is set as a static value for another SSID on the same AP. So, if I have a VLAN set to VLAN 10, I cannot use VLAN ID 10 for RADIUS controlled VLAN users as those users will not get an IP.
Smart Queue QoS is similar to the implementation as in EdgeOS (see HERE). Please note that DPI will not work when using Smart Queue QoS, as traffic will not be offloaded. It’s also worth noting that maximum throughput will be affected when using Smart Queue QoS, as traffic is not offloaded. There are some rough guidelines in the article linked above.
New Features:
Added minimum rate control for UAPs.
Controller Bugfixes/Changes from 5.1.1:
Expose SDN log level.
Added handling of events pushed from backend.
Added TURN support for debug terminal.
Improved RF environment.
Fixed loading of Chinese translations.
Added Polish translations.
Added SV and NL languages for hotspot portal.
Fixed editing image maps.
Added sorting hotspot packages.
Subscribe! Give a Thumbs-Up! Comment and Share!
