EdgeRouter 8 Unboxing, Specs, Simple Setup
Thinking about an EdgeRouter 8? Here is a quick video that will show you what is in the box, what the specs of the router are, how to upgrade to the latest EdgeOS, and run a wizard to get up and going!
Order yours here: http://amzn.to/2bECKF3 on sale for $294!!!!!!!
From the Ubiquiti Site:
Model: ER-8
Dimensions 484 x 164 x 44 mm (19.06 x 6.46 x 1.73 in)
Weight 2.3 kg (5.07 lb)
Max. Power Consumption 35 W
Power Internal AC/DC Power Adapter, 60 W (24V, 2.5A)
Power Input 110 – 240VAC
Button Reset
LEDs Per Data Port Speed/Link/Activity
Networking Interfaces
Serial Console Port
Data Ports
(1) RJ45 Serial Port
(8) 10/100/1000 Ethernet Ports
Layer 3 Forwarding Performance
Packet Size: 64 Bytes
Packet Size: 512 Bytes or Larger
2,000,000 pps
8 Gbps (Line Rate)
Processor Dual-Core 800 MHz, MIPS64
with Hardware Acceleration
for Packet Processing
System Memory 2 GB DDR3 RAM
On-Board Flash Storage 4 GB
Certifications CE, FCC, IC
Rack-Mount Yes
Operating Temperature -10 to 45° C (14 to 113° F)
Operating Humidity 10 – 90% Noncondensing
Need Network Consulting, Design, or Implementation? Contact me! 309.863.5215 or willie at howex5.com!
SUBSCRIBE! Give a Thumbs UP! Comment and Share!
