Ubiquiti EdgeRouter X Hidden Console Port
Sometimes when you’re working with EdgeRouters you will need to connect to the console. Have you ever seen the console port on an EdgeRouter X? Grab your #00 screwdriver and let’s dig into your router! You’ll need a USB to TTL cable and a #00 phillips screwdriver. Get all your parts below and see a picture of my setup! That serial cable will also be used to flash our Meraki AP! 🙂
Wiring Diagram: https://goo.gl/9omhfZ
EdgeRouter X: http://amzn.to/2kppQRY
USB to TTL Cable: http://amzn.to/2BE9Yy7
#00 Screwdriver Set: http://amzn.to/2jhLkfZ
Consulting Contact: https://h5technology.com
Support Agreement: https://h5technology.com/support
Support my channel and keep the lab growing!
Instagram – @howex5
