Ubiquiti Disable SIP ALG (application layer gateway)
Running SIP from behind your EdgeRouter or USG? Having call quality problems or can’t initiate calls? Disable your SIP ALG (application layer gateway). The SIP ALG is supposed to help broker SIP sessions through NAT (network address translation) but usually breaks the calls instead. Here we’ll walk through how to disable the SIP ALG if you have a USG (via the UniFi software) or if you have ANY EdgeRouter from Ubiquiti Networks. Loss of audio, dropped calls, and one way talk path are usually symptoms of an ALG that needs to be disabled.
Most providers have you disabled SIP ALG.
The latest version of UniFi allows you to flip a switch to turn off the SIP ALG. You can disable it via the config tree or command line for the EdgeRouter. From the command line you would type configure to go to edit mode and then issue the command: set system conntrack modules sip disable
Then commit and save your configuration.
EdgeRouter X: http://amzn.to/2ESAlSU
EdgeRouter X SFP: http://amzn.to/2EUsDHF
EdgeRouter Lite: http://amzn.to/2DrDj3w
EdgeRouter 5 PoE: http://amzn.to/2BdlmR4
EdgeRouter 4: http://amzn.to/2EU24m0
EdgeRouter 8: http://amzn.to/2DPi4qj
EdgeRouter Pro: http://amzn.to/2EUIrds
EdgeRouter Infinity: http://amzn.to/2Dkg5Jg
USG 3: http://amzn.to/2EVqGLp
USG Pro: http://amzn.to/2DhXXzK
Consulting Contact: https://h5technology.com
Support Agreement: https://h5technology.com/support
Support my channel and keep the lab growing!
Instagram – @howex5
