Ubiquiti Networks UniFi OS SSL Certificate Installation
Yes — you can install custom SSL certificates on a Ubiquiti Networks UniFi OS (UDM, UDM Pro, UniFi CK2, UniFi CK2+). There are two SSL certs you’ll want to replace. Let’s dig in!
00:00 – Intro
00:10 – What can we put these SSL certs on?
00:31 – Dig in at ssls.com — buy the cheapest cert they have!
01:10 – UniFi OS device SSL overview
03:06 – Create your SSL cert at ssls.com
04:00 – Prepare your certs and key
05:10 – Create Java Keystore
06:55 – Install certs on UDM
09:55 – Reboot UDM
10:17 – Verify
11:30 – Wrap up
UniFi Affiliate Links:
UniFi UDM Base: https://amzn.to/2Q9JykP
UniFi Cloud Key Gen 2: https://amzn.to/3hg8oe5
Consulting/Contact/Newsletter: http://www.williehowe.com
Affiliate Links:
Telnyx Referral Code: https://refer.telnyx.com/cv6cm
HostiFi Affiliate Link: https://hostifi.net/?via=willie
Netool: https://netool.io use code WILLIEHOWE to save at least 10%!
Digital Ocean Referral Link: https://m.do.co/c/39aaf717223f
Contact us for network consulting and best practices deployment today! We support all Grandstream, DrayTek, Obihai, Poly, Ubiquiti, MikroTik, Extreme, Palo Alto, and more!
Instagram – @howex5
