Grandstream GXV3350 Bad Firmware Install Fix
Have you had a firmware load failure on your Grandstream GXV3350? Well — grab a USB drive and the latest firmware and let’s fix it. Unzip and copy the firmware to the root of the USB drive. Power off the phone and insert the USB drive into the USB port on the back. Power on the phone. When the MWI turns from Red to Green hold and press 3 and * at the same time. The device will then begin reflashing the system with the firmware on the USB drive. Once the load is complete and the device reboots you can unplug the USB drive.
Hire us: https://williehowe.com
Telnyx Referral Code: https://refer.telnyx.com/cv6cm
HostiFi Affiliate Link: https://hostifi.net/?via=willie
Netool: https://netool.io use code WILLIEHOWE to save at least 10%!
Digital Ocean Referral Link: https://m.do.co/c/39aaf717223f
Time Stamps:
00:00 – Intro
00:10 – GXV3350 bad firmware load fix
04:15 – Wrap Up
Contact us for network consulting and best practices deployment today! We support all Grandstream, DrayTek, Obihai, Poly, Ubiquiti, MikroTik, Extreme, Palo Alto, and more!
Instagram – @howex5
