Non Pen Roof Mount Assembly
Non-Penetrating Roof Mounts are awesome! You can use them on the ground or on flat roofs. If you want to put it on a roof you can also purchase a matt that goes under it to protect the roof from the metal and whatever you’re using to weight it down. We’re going to be using this non-pen roof mount all over our yard to test WiFi and cameras! You can get yours below!
Non-Pen Roof Mount Amazon Affiliate Link: https://amzn.to/43lLauK
Time Stamps:
00:00 – Intro
00:10 – What’s non-pen roof mount
01:25 – Opening the box
02:56 – What’s in the box?!
04:30 – Assembly!
16:05 – Tighten it all up!
21:28 – Final Product
21:40 – Wrap up
