Easy WiFi Captive Portal With Grandstream
Using a captive WiFi portal with Grandstream is pretty easy! You can use the secure portal and secure redirection without uploading a custom certificate. The Grandstream captive portal leverages the gwn.cloud certificate to handle that. Let’s setup a quick captive portal on a standalone AP and the GCC6021!
